al-yeti Posted June 20, 2019 Posted June 20, 2019 54 minutes ago, norman said: Regardless, if it's not as described eBay have a great returns policy. Nothing to lose imo. You known da score man Just buyit Quote
datadiffusion Posted June 20, 2019 Posted June 20, 2019 'yetiz_hot_dealz_2019', where every system comes with a slightly rattly sounding 1.2Ah Hongfeng lead-substitiute genuine-acid backup battery. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
al-yeti Posted June 20, 2019 Posted June 20, 2019 48 minutes ago, datadiffusion said: 'yetiz_hot_dealz_2019', where every system comes with a slightly rattly sounding 1.2Ah Hongfeng lead-substitiute genuine-acid backup battery. Just get back to work with the scanny enquiries, I been blagging it since you disappeared Quote
Ian2 Posted June 21, 2019 Author Posted June 21, 2019 15 hours ago, al-yeti said: Where r u? East Sussex Quote
Ian2 Posted June 21, 2019 Author Posted June 21, 2019 (edited) 20 hours ago, Specialist said: Hi: You could try dropping a pm to Peter James, he's up your way somewhere. He may be able to help or suggest someone that can. Did you actually change the Engineer code from the factory default code at time of installation ? A lot of DIY installers don't. I must have change it as I have tried the default ###REMOVED### and no work. Ive tried all may usual PIN's but eventually it locks the panel out for 5 min. I have a plan to wire all the 3 sensors in the garage in series and connect to the sensor input for the landing for now. Edited June 21, 2019 by sixwheeledbeast No codes in posts please Quote
datadiffusion Posted June 21, 2019 Posted June 21, 2019 11 hours ago, al-yeti said: Just get back to work with the scanny enquiries, I been blagging it since you disappeared Yeah I read the court transcripts Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
