Posted (edited)
13 minutes ago, james.wilson said:
assuming as you say 0abcd then its not on default codes. But I only know the uk panels and they may have different defaults. I think they are printed on the pcb in the aerial area.
if the code was correct it wouldn't wait for any more digits
The default code has a 0 at the start so I'm not sure whether that's supposed to be the first digit of the code or they mean to use it as a prefix. In any case I've tried 0 + the code and 00.
Edited by Eugene's DIY Den
Posted (edited)
7 minutes ago, james.wilson said:
0 is clear on this panel
On my keypad, the "play/quit" button backs out of the menu.
0 prompts for a user code. Presumably quick codes can be configured in the engineer menu if I can figure out the code to get into it.
All the information needed is in the Installer manual, one thing it says is that Engineer codes should not include the number 0.
  • Upvote 1
Yes, discovered that. The 0 at the start of the default code on every page of the manual must be a misprint.
Ok, thanks guys for all the help. Hopefully the external sounder hasn't been damaged. 12 volts would have been placed on the -ve trigger by my **** up. Will check it tomorrow. Have notified HKC about their document error.
