southwoodian Posted June 22, 2019 Posted June 22, 2019 Hello wondering if anyone can help. I have an infinite alarm which I armed on the remote keypad when I left but when I returned I could not disarm it by either the wireless remote pad or the main keypad, entry set the alarm off. even trying on the main pad the keyboard was lagging in delay, about 10 seconds with each press and the display losses all text for a period. I have checked the mains supply and the internal battery and both metered out ok. I cannot get into any menu. Any ideas Thanks in advance Quote
al-yeti Posted June 22, 2019 Posted June 22, 2019 18 minutes ago, southwoodian said: Hello wondering if anyone can help. I have an infinite alarm which I armed on the remote keypad when I left but when I returned I could not disarm it by either the wireless remote pad or the main keypad, entry set the alarm off. even trying on the main pad the keyboard was lagging in delay, about 10 seconds with each press and the display losses all text for a period. I have checked the mains supply and the internal battery and both metered out ok. I cannot get into any menu. Any ideas Thanks in advance Perhaps it is being jammed? Are you saying the onboard keypad also does not work correctly , I don't know this alarm , I think it's DIY alarm, but just giving you ideas Quote
PeterJames Posted June 22, 2019 Posted June 22, 2019 down power power up mains first battery is probably dead when was it last serviced? Quote
james.wilson Posted June 22, 2019 Posted June 22, 2019 It's not a brilliant bit of kit I assume its been a self service? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted June 22, 2019 Posted June 22, 2019 7 minutes ago, james.wilson said: It's not a brilliant bit of kit I assume its been a self service? I almost opted for this stuff years ago as a cheaper option , then realised the grade one wired Honeywell was better even if no wireless Quote
southwoodian Posted June 24, 2019 Author Posted June 24, 2019 On 22/06/2019 at 17:33, al-yeti said: Perhaps it is being jammed? Are you saying the onboard keypad also does not work correctly , I don't know this alarm , I think it's DIY alarm, but just giving you ideas Hello Yes there is a delay in responding when keys press, and the display lights up but text disappears then takes about 10s to return. initally though it was a supply issue but checked incoming suppl and battery voltages and all ok there. even checked the two fuses , again ok. Being Jammed ?? Quote
southwoodian Posted June 24, 2019 Author Posted June 24, 2019 (edited) On 22/06/2019 at 18:01, PeterJames said: down power power up mains first battery is probably dead when was it last serviced? Hi Peter, I will try this after work, disconnect battery and mains power. wait a couple of minutes before connecting the mains ? I don't remember it being serviced. thanks Edited June 24, 2019 by southwoodian Quote
southwoodian Posted June 24, 2019 Author Posted June 24, 2019 On 22/06/2019 at 22:03, james.wilson said: It's not a brilliant bit of kit I assume its been a self service? Hello James, Yes self serviced, coming from Engineering I like to fix things myself ....where possible. Quote
Specialist Posted June 24, 2019 Posted June 24, 2019 Would that be self serviced or never serviced ?, Your reply to Peter says you don't remember it being serviced. Quote Customers Love us, Intruders Hate us.
