MatDS Posted June 26, 2019 Posted June 26, 2019 Hello. Hoping for some advice, and maybe even someone for this job in North Kent. I've recently moved into a house that has a alarm system fitted in 1996. It has a Menvier Security TS700 panel. I'm no alarm engineer, so will ask a professional to do the work, but is it possible to replace the panel with something like a Texecom panel to enable wi-fi/internet app control, configuration, online alerts on the alarm system? Is there maybe something else that would work to enable these features? Is it as simple as replacing the alarm panel to create a new system using all the old wiring and sensors? Thanks very much for any help! Matt. Quote
james.wilson Posted June 26, 2019 Posted June 26, 2019 yes just a panel upgrade is needed. Any wired panel with app support would do it. Just need to check if the keypads have circuits on them Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted June 27, 2019 Posted June 27, 2019 Yes most modern panels would be fine. Texecom Premier would be a pretty straight forward swap with them having compatibility with any keypad zones or EOL values. If you are getting somebody in to do it, I would let them spec which controls they support tho. 1 Quote
