Al Brown Posted June 27, 2019 Posted June 27, 2019 Hi forum. I have a risc agility alarm. Took the movement sensors down to paint and have reinstalled. They work but are very insensitive you need to get right up to them to set them off. Any ideas? Quote
MrHappy Posted June 27, 2019 Posted June 27, 2019 assuming you have not refitted them in funny way- they sleep after movement if old the lens might be going battery's on the way out.... Quote Mr Veritas God
Al Brown Posted June 27, 2019 Author Posted June 27, 2019 37 minutes ago, MrHappy said: assuming you have not refitted them in funny way- they sleep after movement if old the lens might be going battery's on the way out.... Thanks Mr Happy that’s helped. I’ve realised it’s something to do with the fitting. When I take them down and prop them up on a shelf they work perfectly fixed with the supplies fixing they work but are insensitive. The fixing is part of the back that keeps the tamper switch down. Suspect the back is not fitting snugly when on the wall. Any ideas? Quote
Al Brown Posted June 27, 2019 Author Posted June 27, 2019 Just now, Al Brown said: Thanks Mr Happy that’s helped. I’ve realised it’s something to do with the fitting. When I take them down and prop them up on a shelf they work perfectly fixed with the supplies fixing they work but are insensitive. The fixing is part of the back that keeps the tamper switch down. Suspect the back is not fitting snugly when on the wall. Any ideas? Are the fairly directional? Could it be they are looking at the top 2 feet of the room space when fitted? Quote
james.wilson Posted June 27, 2019 Posted June 27, 2019 need to fitted vertical in the corner at the ceiling Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Al Brown Posted June 27, 2019 Author Posted June 27, 2019 Yep that’s where they are. I’ll experiment, thanks for the advice! Quote
PeterJames Posted June 27, 2019 Posted June 27, 2019 36 minutes ago, sixwheeledbeast said: Fitted upside down? QFA 1 Quote
al-yeti Posted June 27, 2019 Posted June 27, 2019 57 minutes ago, sixwheeledbeast said: Fitted upside down? Gorilla advice excellent Quote
