hello all,
i've just moved into a new property which has a chubb alarm installed. Chubb will not provide me with the code without signing up to a contract. The panel looks exactly the same as the pyronix enforcer but with a chubb logo on.  My question is, can i just swap this panel with a new pyronix enforcer panel or is there a better way.
Thanks for your help
They will/should default it for a call out fee, no company will disclose their engineering codes for obvious reasons.
Alternatively  post your location and someone on here may be able to offer a service/default.
thanks norman, I will give them a call and let you know what they say, I think maybe they were trying it on asking for a new contract
Local independent engineers can default it for you for similar fees or mostly cheaper
Be prepared for a non contracted rate though if you do use them, personally I'd go the independent route.
