Yep a lot of panels used to have these (expecting faults?!) and scrapped them for that reason.
You can sometimes still see on the PCB where the footprint was before they changed them for standard terminals.
Still pretty common on Honeywell stuff, makes easier for swapping out faulty stuff without re-terminating.
Issue can occur if wiring is terminated without it being mounted to the board can make the insides of the terminal block twist.
