Gabs Posted July 15, 2019 Author Posted July 15, 2019 Cound create a central lighting control unit? People interested in that sort of stuff? Quote
james.wilson Posted July 15, 2019 Posted July 15, 2019 I use my hkc panel at home to run my lighting etc. Retro fitting home automation linked to the ia is one direction I'd like to go Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Gabs Posted July 15, 2019 Author Posted July 15, 2019 (edited) 15 minutes ago, al-yeti said: Change title to gabs in security market Ha ha just seeing what it takes to get into it... I'm quite an entrepreneurial person. Just thought because I have knowledge of this industry I might have a better chance of getting going, even something small at first. I could design a quality bell box for example Edited July 15, 2019 by Gabs Quote
MrHappy Posted July 15, 2019 Posted July 15, 2019 (edited) 7 minutes ago, Gabs said: Ha ha just seeing what it takes to get into it... I'm quite an entrepreneurial person. Just thought because I have knowledge of this industry I might have a better chance of getting going, even something small at first. I could design a quality bell box for example I think alarms is a declining market, most small manufactures of alarm stuff have gone. A bell box is plastic moulding & electronics for £20 odd, A tool box is plastic mounding no electronics & about £20 odd ? Edited July 15, 2019 by MrHappy 1 Quote Mr Veritas God
Gabs Posted July 15, 2019 Author Posted July 15, 2019 8 minutes ago, MrHappy said: I think alarms is a declining market, most small manufactures of alarm stuff have gone. A bell box is plastic moulding & electronics for £20 odd, A tool box is plastic mounding no electronics & about £20 odd ? I know what you mean, a tool box would be a good idea, but I can't just make one and expect to sell it. What is your tool box missing that you could do with? If I can find a problem with a product fix it, I can have a much better chance of someone investing. E.g. Gabs goes to Dragon's Den, he has to convince the savages sat in front of him his product is worth selling, a product the same as 1000s of others on the market. However, if he can show that he has found a problem and fixed it he will more likely get money for a factory and an injection moulding machine... Then MrHappy will buy it because he is happy a problem he identified has been solved. Is there anything that poses a problem in your work-related life you could do with being solved? Quote
MrHappy Posted July 16, 2019 Posted July 16, 2019 Plastic moulding- A shallow curricular box to mount an eyeball camera on, with 4 flattened sides for conduit entry A box to screw on the wall behind the telly big enough to take a brick psu & have enough space to terminate shotgun to 12v or cat5 onto coax for the dvr A plastic conduit box to connect to a RSC like the MK dantech but plaggy Quote Mr Veritas God
sixwheeledbeast Posted July 16, 2019 Posted July 16, 2019 3 minutes ago, MrHappy said: A shallow curricular box to mount an eyeball camera on, with 4 flattened sides for conduit entry Most eyeball cameras have optional conduit backboxes or rings? 3 minutes ago, MrHappy said: A box to screw on the wall behind the telly big enough to take a brick psu & have enough space to terminate shotgun to 12v or cat5 onto coax for the dvr A boxed PSU? 3 minutes ago, MrHappy said: A plastic conduit box to connect to a RSC like the MK dantech but plaggy What's up with a normal JB or the Dantech one. Would have to get graded to be useful. Quote
MrHappy Posted July 16, 2019 Posted July 16, 2019 1 hour ago, sixwheeledbeast said: Most eyeball cameras have optional conduit backboxes or rings? yes, however a Hik one is £10ish & only suitable for for certain products, often has a hole for PG gland, can't be used as an elbow or a t So plaggy, white or back, round plain lid make your own fixing holes 38 minutes ago, sixwheeledbeast said: A boxed PSU? a 5a one would be quite big behind a telly 38 minutes ago, sixwheeledbeast said: What's up with a normal JB or the Dantech one. Would have to get graded to be useful. in fact make a circuit board to fit in a terminal box Quote Mr Veritas God
sixwheeledbeast Posted July 16, 2019 Posted July 16, 2019 6 minutes ago, MrHappy said: yes, however a Hik one is £10ish & only suitable for for certain products, often has a hole for PG gland, can't be used as an elbow or a t I don't fit Hik so no idea. 6 minutes ago, MrHappy said: a 5a one would be quite big behind a telly Dantech have a wide but very slim one for upto 8 cam jobs There's also Elmdene Easyfit or other one's that look like a slim IP box as options. 6 minutes ago, MrHappy said: in fact make a circuit board to fit in a terminal box Butcher a normal JB with some cheap plastic mount? Quote
