Hi,
      I've just self installed the above panel and I'm getting the following error message can any one please help me solve this problem
error message - device 01 485 fail trd
Kind Regards
Alan
22 minutes ago, glaker said:
Hi,
Kind Regards
Alan
2nd panel? Or you remove and adding devices adhoc
Hi, no its a new panel, do you mean the keypad devices or the pir inputs? I have nothing connected to the keypad and using 6 inputs as intruder and one fire input connected to the main panel
Go to assign keypads and readers and check all other addresses apart from 0.
I suspect one is programmed as a reader/keypad.
Set them to unused.
0 should be a keypad.
Come out of engineers mode and that should sort it hopefully.
Grant
  • Like 1
