al-yeti Posted July 22, 2019 Posted July 22, 2019 1 hour ago, james.wilson said: Intruder and hold up Hardcore , need to be in with lingo of you alarm gorillas Quote
sixwheeledbeast Posted July 22, 2019 Posted July 22, 2019 Depending on the system I much prefer the Aico low voltage option now. I would consider for it to be an auxiliary/ancillary it should have some way to function on it's own, which is not the case with your standard 12v smoke. I would argue that the fire detector being considered ancillary is not a good idea, ancillary by definition makes it less important than the system it's ancillary to. Quote
al-yeti Posted July 22, 2019 Posted July 22, 2019 50 minutes ago, sixwheeledbeast said: Depending on the system I much prefer the Aico low voltage option now. I would consider for it to be an auxiliary/ancillary it should have some way to function on it's own, which is not the case with your standard 12v smoke. I would that the fire detector being considered ancillary is not a good idea, ancillary by definition makes it less important than the system it's ancillary to. Do texe have a wireless with built in sounder? Quote
sixwheeledbeast Posted July 22, 2019 Posted July 22, 2019 Yep wireless only tho. They are labelled up as a Grade 2 item funnily enough. There's also a stand alone receiver module so you can stick em on any controls. Quote
aissecur Posted July 23, 2019 Posted July 23, 2019 yep it a ricochet system... I fitted one of the wireless smokes and seems ok Quote
datadiffusion Posted July 24, 2019 Posted July 24, 2019 On 22/07/2019 at 22:42, sixwheeledbeast said: They are labelled up as a Grade 2 item funnily enough So they have tamper / base removal detection? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
datadiffusion Posted July 24, 2019 Posted July 24, 2019 On 22/07/2019 at 18:11, sixwheeledbeast said: Depending on the system I much prefer the Aico low voltage option now They are certainly good, just wish they'd update the look of them. AICO had a cloud system waiting in the wings for their mains alarms it would seem, but no mention on the website currently, it's vanished... Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
aissecur Posted July 24, 2019 Posted July 24, 2019 I've used a lot of aico's domestically with very few issues - they get a thumbs up from me A cloud based system would be interesting Quote
datadiffusion Posted July 24, 2019 Posted July 24, 2019 (edited) There is a white box that I assume would connect via wifi to t'internet, and it would work only with the newer SmartLink enabled devices There was even a portal website but nothing on the homepage other than Username / PW login boxes If you look at some pics on the news section, you can see boards at exhibitions and the demo truck detailing the new system 'coming soon' but that was back in April. All other mention seems to have been removed with the new website. I do wonder if they have realised the service would be more useful to landlords and that a 4G sim-on-chip built into every box and then activated for a monthly charge would get more of an uptake? Edited July 24, 2019 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
