d-tec services Posted July 22, 2019 Posted July 22, 2019 Hi all I have a G2-20 panel which is randomly setting off, when I look on the log it has the detector which triggered the false alarm then it will always have Batt Mis proceeding the alarm. I have checked the battery but it still does it, is this a faulty panel and if so what is the new equivalent of a G2-20 as I have read that they are now obsolete? Cheers Quote
james.wilson Posted July 22, 2019 Posted July 22, 2019 G2 is still available But I'd check everything before condemning it Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted July 22, 2019 Posted July 22, 2019 I don't fit Galaxy but would be surprised if they dropped the 2-20. Control panels are very rarely faulty from experience, you need to rule out external factors as throwing a panel at it is relatively expensive and will piss the customer off if it's something else. There could be something shorting to ground and dragging the system down, or maybe even the battery is faulty but appears ok if you test it. Not an exhaustive list of what it could be tho. Quote
datadiffusion Posted July 22, 2019 Posted July 22, 2019 Dodgy battery spade connector? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
al-yeti Posted July 22, 2019 Posted July 22, 2019 28 minutes ago, d-tec services said: Hi all I have a G2-20 panel which is randomly setting off, when I look on the log it has the detector which triggered the false alarm then it will always have Batt Mis proceeding the alarm. I have checked the battery but it still does it, is this a faulty panel and if so what is the new equivalent of a G2-20 as I have read that they are now obsolete? Cheers How old is system panel battery? I would change that first Standard on these to show bat mis when they dodge , only ever got one panel with that fault similar and was panel Change battery Quote
d-tec services Posted July 22, 2019 Author Posted July 22, 2019 I had a 12 ah battery installed, changed it now to a 7 ah, does it cause the PSU to work harder to charge up a bigger battery? Quote
james.wilson Posted July 22, 2019 Posted July 22, 2019 Yes especially if your pushing more day mode current Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
timeserved Posted August 27, 2019 Posted August 27, 2019 On 22/07/2019 at 19:40, d-tec services said: I had a 12 ah battery installed, changed it now to a 7 ah, does it cause the PSU to work harder to charge up a bigger battery? Only on a complete discharge or new battery senario the rest of the time it's on trickle charge which hardly takes anything. Regards TS Quote
