Advanced networking
Hi, just a quick question
I have a new site with 3 separate buildings the 3 will have its own advanced panel,
i shall be linking the 3 stations up via a network card.
the question I have if say building 1 goes into fire will it send the others 2 building in to a fire state also? Or will just a alert come up To say building 2 is in fire?
As I only want a alert
thanks
Thrones
1 hour ago, sixwheeledbeast said:
All down to how you set it up in the programming.
And latest firmware yes? I see some network features added to newer firmware
Or that doesn't matter?
36 minutes ago, Prodigious said:
Hi guys,
anyone got any advice on this for me?
Im looking to set up next week
You have answer above, swb gave it to you
Now all you need to do is hire someone with latest software and knows what there doing to programme it for you
Last thing you want is to mash up the alerts and no signal goes through in an emergency
Advance would also help you if your legit
ok no problem!
I was just asking where in programming would this be!?
Ive been doing this for over 18 years so yes you could say I’m legit!
I’ve just never done the original topic before!
As for signaling my friend all this will be tested thoroughly at commissioning  stage!!
Thrones
14 minutes ago, Prodigious said:
ok no problem!
Probably no one here has done this setup hence no detail
I know one engineer but they have rigs setup in there office and always in touch with tech , seemed to k ow how to programme what they want
I assume you can get the info
