datadiffusion Posted August 6, 2019 Posted August 6, 2019 53 minutes ago, al-yeti said: Eaton basher How do you know these things - who tells you? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
al-yeti Posted August 6, 2019 Posted August 6, 2019 43 minutes ago, datadiffusion said: How do you know these things - who tells you? H , he sells stalking info on ebay Quote
datadiffusion Posted August 6, 2019 Posted August 6, 2019 Oh, well that's OK then. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
james.wilson Posted August 7, 2019 Posted August 7, 2019 Op is the output of the sensor relay based? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
mauog Posted August 7, 2019 Author Posted August 7, 2019 Ops I let the thread control My porblem is to set a correct value in the filed "Pulse count". Lower value increase the possibility of a false alarm and a high value cannot identify a real intrusion event... Quote
james.wilson Posted August 7, 2019 Posted August 7, 2019 If its a relay output marked nc then I would set at 300ms and 1 pulse Do you have the manual for the detector? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
mauog Posted August 7, 2019 Author Posted August 7, 2019 40 minutes ago, james.wilson said: If its a relay output marked nc then I would set at 300ms and 1 pulse Do you have the manual for the detector? In the manual the only thing connected to pulse time is: Pulse 4 ÷ 6 ms Risco anyway recommend to set for this kind of device a loop response of 1ms but doesn't specify the number of pulse count... Quote
james.wilson Posted August 7, 2019 Posted August 7, 2019 I assume its like a vibration sensor but I'd expect noise on the cables to cause issues at 1ms Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted August 7, 2019 Posted August 7, 2019 2 hours ago, james.wilson said: Op is the output of the sensor relay based? It's two wire sensor on movement dude Quote
MrHappy Posted August 7, 2019 Posted August 7, 2019 does the string need wetting to get a low Ω's Quote Mr Veritas God
