Changed to wire links. Reset config, disabled box tamper, let it boot up, reset time/date, all zone lights showed unlit. So progress I think? I then proceeded to add zone 3 (passage) as it's easier to test that while I'm busy with it since the keypad is 1m away from it. configured that zone as an interior instant NC. (Is this correct? it's the PIR from previous PIR picture), it does not detect when I stand there. the sensor itself lights up, the zone on the keypad does not. Also, that trouble light is illuminated still.
Alright I've made some progress! Might make it easier. I've assembled a TTL to USB device and mapped the COM 1 port on the 412 and managed to hack it all together so I can use Wintex to see the panel. Now to figure how to go from there
  On 09/08/2019 at 15:48, Shadrack said:
The firmware on the panel is Premier 412 Version 7.1, would updating be possible for such an old panel? without bricking it.
Expand
Forget firmware update no point
Now you know wire links allowed faults to clear because it's not setup for resistors
Possibly
But carry on , if you manage to programme it fine
If not you can use without resistors and global tamper if it has it
DIY no big deal how you do it
Expand
Also you need to remove the resistor from the PIR , if your doing it without resistors,
If you join and open wire atnpir end that should open and close the zone , perhaps pirs are shot
I've measured the resistance over the wires for zone 3, 3.3k, then when someone walks in front of it, changes to open circuit. PIR seems fine. Rechecked wiring. Seem's correct.
used multimeter on panel side to confirm the same (in case a wire broke in the ceiling etc), works fine. I wire it up to zone 3 on the panel, so I should program it to:
Zone: 03
zone type: 04 Interior instant
zone wiring: Single EOL - N/C
Partition: 1
Attributes 1: Enable Bell, Enable Instant Strobe, Enable transmission
Attributes 2: Enable Manual Bypass, Enable stay bypass
Attributes 3: none
Zone text: passage
correct?
I've tried all, unless I select Normally Open, all list as "active", even when using jumpers direct from com to zone. Any advice on that? I am very confused at this point. PS, thanks for all your help so far everyone. I've indeed made progress through your help!
Expand
Single eolwould mean put resistor back in PIR if you removed it
Does anyone have the newer firmware for the 412? I can only find the firmware for Premier elite, which this is not. trying to fix the issue of even all shorted, all zones say active/trouble
