mfudala Posted August 9, 2019 Posted August 9, 2019 Hi, I just came home and it seemed like there was a power cut. I turned on the electricity power plugs and the power came back on however the abs is going off, it is only the alarm box making the noise and there is a red light next to the settings(?) icon. I was considering turning the power off just to stop the noise but than the alarm outside goes off. I have no idea how to deal with it and it is too late to contact any engineers. Please help Quote
PeterJames Posted August 9, 2019 Posted August 9, 2019 Its never to late to contact engineers, alarm companies run 24/7 for exactly this reason. If your alarm was installed after 97 it will only sound for 20 mins, if it was after 2010 just 17 minutes Quote
sixwheeledbeast Posted August 9, 2019 Posted August 9, 2019 This is what happens to a system that is not serviced regularly. Switching the power back off will only make it worse as you will trigger the outside sounder. Companies do operate 24/7 however they may not respond without a contract in place. The settings icon is likely a fault spanner (scantronic)? You could try putting in the code slowly and firmly just incase the keypad is worn and a digit was missed. Quote
mfudala Posted August 9, 2019 Author Posted August 9, 2019 Thank You for the reply 3 minutes ago, sixwheeledbeast said: This is what happens to a system that is not serviced regularly. Switching the power back off will only make it worse as you will trigger the outside sounder. Companies do operate 24/7 however they may not respond without a contract in place. The settings icon is likely a fault spanner (scantronic)? You could try putting in the code slowly and firmly just incase the keypad is worn and a digit was missed. Hi, thank you for the reply. We have only moved in a couple weeks ago and the landlord said the alarm is not in use and she didnt even give us any code. I dont even know who to call right now as there is no company on the alarm, I guess I will just contact the landlord tomorrow. Quote
sixwheeledbeast Posted August 9, 2019 Posted August 9, 2019 Best to get hold of the landlord if your place is rented it's there responsibility. Either make sure they get it working and serviced regularly or make sure it's disabled and powered down correctly. Landlord may call it "disabled" if they only use it when there is no tenant but that doesn't help you in this situation you should have the code. Quote
PeterJames Posted August 9, 2019 Posted August 9, 2019 Speak to your landlord they will have to call someone out for you, they have a duty of care. If they havent bothered with having it serviced its their responsibility Quote
MrHappy Posted August 9, 2019 Posted August 9, 2019 51 minutes ago, PeterJames said: Its never to late to contact engineers, I would have replied earlier but was in the middle of 90ml round trip to attend a ringing alarm... Quote Mr Veritas God
