Eugene's DIY Den Posted August 11, 2019 Author Posted August 11, 2019 (edited) 8 hours ago, al-yeti said: You need scroll until it says add to point number /zone from memory I only done this to a couple of sites because customer wanted it all common names I added it to point number 50 (the first one)., and it now triggers an alarm ok. The mystery is how to add it to a zone. James Wilson above suggests it can be a point or a zone but not both, but the instructions suggest that points can be added to zones. Maybe that's just an error. They also say that the reason for this is to conserve zones, suggesting that each added RF device would be on a separate zone. However later they say the device can be on any of the 70 zones (it doesn't have to be one of the physical 10 zones on an unexpanded panel). They talk about "mapping" onto zones, but there's no mention of this in the installation manual (only mapping outputs). Edited August 11, 2019 by Eugene's DIY Den Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted August 11, 2019 Author Posted August 11, 2019 2 minutes ago, james.wilson said: It sounds like you added it to a point. You cannot also use that zone if using points. Just change the point options for that device as if it was a zone Yes I added it as a point, but firstly can I add it to my existing wired zone (I want to be able to turn off all PIRs, wired and wireless when partially arming. I know I can have separate zones for wired and wireless PIRs, but I'd like to keep them together) and secondly if I add a second PIR, how can the two PIRs be grouped together as a single zone? Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
james.wilson Posted August 11, 2019 Posted August 11, 2019 Your confusing what zones are imo If your using points 50 to 59 then you can't use zone 5 Once all your zones and points are running correctly you will use the point/zone options per device to remove from part set a and b. You don't 'map' anything Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted August 11, 2019 Posted August 11, 2019 (edited) 2 hours ago, james.wilson said: It sounds like you added it to a point. You cannot also use that zone if using points. Just change the point options for that device as if it was a zone Exactly 2 hours ago, Eugene's DIY Den said: Yes I added it as a point, but firstly can I add it to my existing wired zone (I want to be able to turn off all PIRs, wired and wireless when partially arming. I know I can have separate zones for wired and wireless PIRs, but I'd like to keep them together) and secondly if I add a second PIR, how can the two PIRs be grouped together as a single zone? You can't have two devices on one one zone or point , each device has to have its own zone or point If you mean can you have a wireless PIR on a wired zone like zone 1 onboard it can be wireless instead Yes you can turn them off, but that you can do with part set A or B or even setting zones up on blocks if you have other uses Just add all your devices and those pirs you want to exclude on part set a just select that option in each point or zone and it won't arm on part set Edited August 11, 2019 by al-yeti Quote
Eugene's DIY Den Posted August 11, 2019 Author Posted August 11, 2019 Ok, I sort of understand this. I think I'll just add the two PIRs in the zone space above the 10 hardwireable zones (keeping the remaining unconnected ones as spares). So presumably once the PIRs are setup as "logical"/wireless zones, I can walk test them? Also what's the advantage of using points rather than zones? Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted August 11, 2019 Author Posted August 11, 2019 2 hours ago, james.wilson said: If your using points 50 to 59 then you can't use zone 5 So are points 50 to 59 then already mapped/hardwired to zone 5 and any point that activates, triggers an alarm on that zone? The manual is very confusing about this and talks about "mapping a point onto a zone". Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted August 11, 2019 Author Posted August 11, 2019 Set the PIR up on a zone an excluded it from my part sets, so all's well. Thanks for the help! Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
al-yeti Posted August 11, 2019 Posted August 11, 2019 5 hours ago, Eugene's DIY Den said: Ok, I sort of understand this. I think I'll just add the two PIRs in the zone space above the 10 hardwireable zones (keeping the remaining unconnected ones as spares). So presumably once the PIRs are setup as "logical"/wireless zones, I can walk test them? Also what's the advantage of using points rather than zones? Points instead of zones? Emmmmmm If you have data pirs wired , advantage is everything is called a point , for customer better that way Other than that don't know lol Quote
james.wilson Posted August 11, 2019 Posted August 11, 2019 Points save using real zones. Irish fw is different to UK but UK allows zones to be used with rf even if expanders are not connected Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
