Hi,
We have had a pm360 system with the gateway box and a seperate keypad to set the alarm with (nothing visual at all).
We have had the system for nearly 3 years and I am looking at alternatives.
Will it be cheaper / easier to purchase a new system entirely, or will it be better to do a full hard reset of the adt system to try and use it as a standalone visonic alarm? (once the contract has been cancelled of course.
I am tech savvy, no issues with fiddling with things!
Thanks,
Matt
11 minutes ago, sixwheeledbeast said:
Pretty sure Visonic ADT is not compatible with off the shelf Visonic.
Plenty visonic ADT on eBay tho......
2 hours ago, Mdc15 said:
Exactly this is what made me suspicious, if it was locked to ADT then their wouldn't be a second hand market on ebay?
If anything this probably increases the value on the likes of eBay, they do use a slightly different freq, not locked but only compatible with like for like rx.
Just search visonic ADT on eBay plenty available , used and new
But you need to find out how much ADT charge to reset it for you , or you can try and default it yourself
