Prodigious Posted August 18, 2019 Posted August 18, 2019 Hi guys! I have a hik vision nvr with 2 is cameras which were rather pricey. wondering as to what other camera makes out there are compatible with hik vision as need 1 extra one thanks Quote Thrones
al-yeti Posted August 18, 2019 Posted August 18, 2019 36 minutes ago, Prodigious said: Hi guys! I have a hik vision nvr with 2 is cameras which were rather pricey. wondering as to what other camera makes out there are compatible with hik vision as need 1 extra one thanks What's your budget per camera and what is existing model you installed? Some Onvif cameras can work with hik Quote
james.wilson Posted August 18, 2019 Posted August 18, 2019 Which cameras as I wouldn't call hik pricey? 1 Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted August 18, 2019 Posted August 18, 2019 24 minutes ago, james.wilson said: Which cameras as I wouldn't call hik pricey? Depends which hik cameras you? Quote
PeterJames Posted August 18, 2019 Posted August 18, 2019 2 hours ago, james.wilson said: Which cameras as I wouldn't call hik pricey? Compared to the stuff you see on amazon they are, but we have just had that conversation on the Oswu alarm system topic. OP you get what you pay for, especially so with CCTV. In order to make something cheaper you have to produce it cheaper, like using plastic lenses that warp in the sun and cant be focused or reject chips that work but have been rejected due to dead pixels or similar. I dont use Hik but they are what I would call the premium cheap end of the market, Hik are really good value for money from what I have seen of them. If you think Hik are expensive take a look at Mobotix, 6 times the price. In answer to your question though any Onvif camera will work Quote
sixwheeledbeast Posted August 18, 2019 Posted August 18, 2019 As above really Onvif should be compatible but your most likely to have the least messing about if you fit a Hik. Trap you to a plug and play platform like that. Quote
Prodigious Posted August 18, 2019 Author Posted August 18, 2019 I have a DS-7604NI-K1/4P NVR with 2x POE cameras DS-2CD2345FWD 2.8 Which I paid £376 at dvs the cameras were roughly£87 each. I will probably get another hik camera but for future reference are there alternatives to go with a hik nvr? And do they just plug and play like a hik camera does Quote Thrones
Prodigious Posted August 18, 2019 Author Posted August 18, 2019 Yes and I was just answer a question from about which asked what equipment I had Thank you though Quote Thrones
al-yeti Posted August 18, 2019 Posted August 18, 2019 20 minutes ago, Prodigious said: Yes and I was just answer a question from about which asked what equipment I had Thank you though Stick to what you have , everything else will probably be more expensive if aiming for quality If you want cheap and cheerful you can try any Onvif camera generally Quote
