ryback Posted August 31, 2019 Share Posted August 31, 2019 Hi folks. I acquired a second hand Visonic kit (panel + sensors) from a guy who used to have an ADT subscription. He terminated his contract with ADT and they left him the alarm. I purchased it assuming it would be simple to "reset" the panel and fit it to my needs. I sadly found it isn't. Although I can do a reset (green light = success?), I cannot log into the panel, either via USB port or AlarmInstall app. As far as I was told later, ADT visonic panels are locked and can only be accessed by ADT remotely. Understanding the forum policies of not publishing defaulting info in public forums, I would just to know if it possible (not how) to default (reset) this panel to use without paying ADT a fee, or it's simply impossible. Thanks. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 31, 2019 Share Posted August 31, 2019 3 hours ago, ryback said: Hi folks. I acquired a second hand Visonic kit (panel + sensors) from a guy who used to have an ADT subscription. He terminated his contract with ADT and they left him the alarm. I purchased it assuming it would be simple to "reset" the panel and fit it to my needs. I sadly found it isn't. Although I can do a reset (green light = success?), I cannot log into the panel, either via USB port or AlarmInstall app. As far as I was told later, ADT visonic panels are locked and can only be accessed by ADT remotely. Understanding the forum policies of not publishing defaulting info in public forums, I would just to know if it possible (not how) to default (reset) this panel to use without paying ADT a fee, or it's simply impossible. Thanks. From what I came across none were locked unless it's new procedure from them But defaulting is possible Quote Link to comment Share on other sites More sharing options...
ryback Posted September 1, 2019 Author Share Posted September 1, 2019 21 hours ago, al-yeti said: From what I came across none were locked unless it's new procedure from them But defaulting is possible Sorry if this sounds silly, but what’s the difference between unlocking and defaulting? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted September 1, 2019 Share Posted September 1, 2019 5 hours ago, ryback said: Sorry if this sounds silly, but what’s the difference between unlocking and defaulting? Defaulting - restoring to factory settings and codes Unlocking - so defaulting can be achieved , if locked you have mess around to unlock on many panels and some never will Mostly the defaulting procedure is done incorrectly lol Quote Link to comment Share on other sites More sharing options...
ryback Posted September 2, 2019 Author Share Posted September 2, 2019 Understood. Thanks for the clarification. I believe I can default the panel as I run the “restore to factory setting procedure” (please no defaulting info REMOVED ) and the panel emits a green light and success tone. My problem however is that I cannot interface with the panel. This model (PM-360) has no keyboard and it only can be programmed by connecting to it. I tried: - USB (regular USB cable): Windows does not detect any device - WiFi (virtual keyboard via AlarmInstall app - local option): connection rejected Any ideas on how to connect to the panel? Regards Quote Link to comment Share on other sites More sharing options...
Trav2176 Posted September 26, 2019 Share Posted September 26, 2019 Hi I'm an ADT installer. Some of these panels can be a bit of a pain and don't work if they are the older version. You have to either REMOVED(I can't remember which from the top of my head) and then it should beep or flash a light. You have to then search and connect to the panels wifi in your phone settings. The wifi SSID is usually the panels ID number. The password for the wifi is the panels serial number. Haven't played with one for a while but hopefully you'll have some luck! Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 26, 2019 Share Posted September 26, 2019 Useful info Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
datadiffusion Posted September 27, 2019 Share Posted September 27, 2019 Hang on isn't this defaulting info in public? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
al-yeti Posted September 27, 2019 Share Posted September 27, 2019 2 hours ago, datadiffusion said: Hang on isn't this defaulting info in public? What defaulting info? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted September 27, 2019 Share Posted September 27, 2019 Is it? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
