2 hours ago, ryback said:
Not sure if holding reset defaults installer code... seems like not. So far trying codes one at a time... 62 in 2 hours… this will take days... assuming it's a 4 digit code, if the code is longer it will be almost impossible
You in I.T? As in what you do for a living
  • Upvote 1
I work in IT related tasks. I'm tech-savvy. I was thinking of writing a program to brute-force test all the codes, but it's too much work
In that case my advise to you , is take it on the chin and put this panel in bin or back on eBay
Buy a new alarm like an enforcer which probably right up your street being nice DIY panel to an extent
I think the main sentiment was not to waste time on a duffer rather than a specific recommendation TBF
  • 3 weeks later...
Yes , I think sometimes or allot of the time , its wasted on old panels , yet a everything else is updated around the house
  • 5 months later...
Hi ryback
What code did you find in the end as the default Adt installer code?
I have just moved into a house with the same alarm and also can't find the installer code after defaulting.
Thanks.
In the unlikely event that he replies please don't post codes on the forum.
Thanks in advance
