datadiffusion Posted September 27, 2019 Posted September 27, 2019 (edited) I've got a strange sounder at home, it's a Scanny eurobell plastic case with strobe upgrade for sure, but with a high security, anti drill, thick steel cased backplate that I am certain is nothing to do with scanny... Have a feeling it came from a bank. Oddly the tamper switches are like the ones I have on my fruit machine collection* and even more oddly they are the type that have a 'cheat' position where you can pull the plunger outwards to make (with a machine) the central unit think the door is closed so you can playtest but still eb able to adjust stuff. *of 2 Edited September 27, 2019 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted September 27, 2019 Posted September 27, 2019 19 hours ago, Jack b said: It's certainly done well for an early 2000s sounder Not if they failed in 2001... 9 minutes ago, datadiffusion said: Oddly the tamper switches are like the ones I have on my fruit machine collection* Quote Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted September 27, 2019 Posted September 27, 2019 You see that Tommy? That's you that is! 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted September 27, 2019 Posted September 27, 2019 I still use that comment with the Mrs, she hasn't got a clue what I'm referring to just thinks I'm a mongo Quote Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted September 27, 2019 Posted September 27, 2019 Have you considered that she does know the reference but still thinks that anyway? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted September 27, 2019 Posted September 27, 2019 Good point, well put. Quote Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted September 27, 2019 Posted September 27, 2019 ta 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Jack b Posted September 30, 2019 Author Posted September 30, 2019 On 27/09/2019 at 16:36, datadiffusion said: I've got a strange sounder at home, it's a Scanny eurobell plastic case with strobe upgrade for sure, but with a high security, anti drill, thick steel cased backplate that I am certain is nothing to do with scanny... Have a feeling it came from a bank. Oddly the tamper switches are like the ones I have on my fruit machine collection* and even more oddly they are the type that have a 'cheat' position where you can pull the plunger outwards to make (with a machine) the central unit think the door is closed so you can playtest but still eb able to adjust stuff. *of 2 I think the microswitchs are known as cherry, thorn used to use. Quote
datadiffusion Posted September 30, 2019 Posted September 30, 2019 Yes Cherry ones, available freely without the 'cheat' position so very odd, unless changed. You could fit them to certain plastic cased Scannys too to add case to wall tamper, there is a cutout in the rear of the case, sometimes the switch part number is stamped into the plastic IIRC 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
