james.wilson Posted September 10, 2019 Posted September 10, 2019 I'm not sure dt will I'd expect the pir side to have the same issue. You might be better with perimeter detection Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
norman Posted September 10, 2019 Posted September 10, 2019 55 minutes ago, PodMan said: It’s not a conservatory it’s a heat issue in a large room that is a kitchen/Dining/sitting room with 6m bifolds floor to ceiling. Last Sunday with sun and cooking in the room through the doors the temp rise caused the device not to be able to detect a us moving. No false alarm just did not detect. Pyronix Tech said dual tech or similar. Cheers If you are cooking then the alarm won't be set? Quote Nothing is foolproof to a sufficiently talented fool.
PodMan Posted September 10, 2019 Author Posted September 10, 2019 I know that alarm won’t be working when cooking it was referencing the heat issue on an only mildly sunny day. Mid summer would do the same with no cooking Quote
PodMan Posted September 10, 2019 Author Posted September 10, 2019 3 hours ago, james.wilson said: I'm not sure dt will I'd expect the pir side to have the same issue. You might be better with perimeter detection Fitting a prom sensor on the bifolds would be difficult and ugly. What about the DQ Quote
james.wilson Posted September 10, 2019 Posted September 10, 2019 Any sensor with pir in it is going to have issues around 35+ ambient Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
norman Posted September 10, 2019 Posted September 10, 2019 2 hours ago, PodMan said: I know that alarm won’t be working when cooking it was referencing the heat issue on an only mildly sunny day. Mid summer would do the same with no cooking My pref would be a DT (for false alarms, not non alarming reasons) and to contact to the door. If installed correctly they are unobtrusive and if the door is grey etc, then they can be colour matched. As above a DT won't cure your issue as both technologies have to simultaneously activate to trigger the panel, the PIR element will still struggle in hot environments. In real terms they are only likely to enter via the doors (regardless of protection) and will go elsewhere. Quote Nothing is foolproof to a sufficiently talented fool.
PodMan Posted September 10, 2019 Author Posted September 10, 2019 7 minutes ago, norman said: My pref would be a DT (for false alarms, not non alarming reasons) and to contact to the door. If installed correctly they are unobtrusive and if the door is grey etc, then they can be colour matched. As above a DT won't cure your issue as both technologies have to simultaneously activate to trigger the panel, the PIR element will still struggle in hot environments. In real terms they are only likely to enter via the doors (regardless of protection) and will go elsewhere. Hi to all thanks for your help and a decision will be soon made. Lots to think about. Cheers Quote
PeterJames Posted September 10, 2019 Posted September 10, 2019 Hi just for clarity a pir works using passive infra red to detect movement of heat, if the ambient temp is high then it will struggle to detect. A dual technology detector is two different types of detection in one Microwave which uses radar dopler to detect, and passive infra red, both radar doplar and the passive infra red have to detect before the detector activates. Which means you will still have the same problem with it not detecting. Not familiar with the Pyronix tat so I could be wrong but surely all new kit is two way technology, therefore the detector wont be working while the alarm is unset anyway? HKC is the only manufacturer that makes a wireless DT not that it would work in your situ 2 Quote
sixwheeledbeast Posted September 10, 2019 Posted September 10, 2019 Texe have had one for ages. Needs perimeter IMO. 2 Quote
james.wilson Posted September 11, 2019 Posted September 11, 2019 Agreed Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
