hi , wonder if anyone could help with problems concerning yale wireless alarm hsa 3000 series
 when on sunny days the alarm go,s off on its own , i found out its the tamper switch inside the alarm siren box and the cover must expand with the heat of the sun causing the tamper switch to move , ive tried a few times to pack the switch so the switch is tight closed but after a while im back to square 1.
 the question is can i disconnect the tamper switch or loop the yellow and red wires together or maybe just fit a 12v on/off switch to bypass this. any help appreciated
Posted (edited)
hi yea there are 2 wires going to the micro switch do you say its ok to loop the 2 wires together and remove the switch , the switch do,s plug into a pcb but id rather not mess around with it , the wire are yellow and red
Edited by gazh
Thanks lads for the info its much appreciated , going to replace the whole lot soon just needed this sortin for now..which is the best wireless upgrade to go for
Hkc then perhaps texecon
1 hour ago, aissecur said:
not really used much HKC
You haven't lived until you have had the soft breeze of HKC wireless transmission wafting through your hair
