Good afternoon guys
Help please. Ive added a Bosch Commercial ISC-CDL1-WA15G to zone 11 (extension board) on or Texecom Elite 24 panel.
However showing tamper fault. Ive check continuity of wires to and from panel to pir all ok. Ive used resistors for eol instead of built in pins.
What am i doing wrong?
Have you made sure you have clipped the detector front in fully?
If it has built in resistors are they disabled?
Is zone 11 mapped to something?
Is there a reason why zone 10's COM is in the Zone 11's one?
  • Like 1
Nicely spotted :yes:.
Cos you hardcore swb dude that's y
Sorted.
The comment from 6WB was correct i did place common from 10 into 11. Quick experiment which I didn’t correct before photo.. Anyway that was a good spot.  I actually found my multimeter crocodile leads had an annoying intermittent break so I’ve replaced them.
To fix the issue i simply swapped the blue and green zone 11 around and presto sorted.  I did have another issue which i need to sort though. Ill post a new topic though.
