Guest Patmitch Posted November 18, 2004 Posted November 18, 2004 Quite A long time ago I aquired a JSB regent 8 zone panel and somehow I have lost the paper work containing the codes to program the thing. Is there anyone out there that can help me as I am a Yorkshire man and refuse to go and aquire another alarm
Guest Posted November 18, 2004 Posted November 18, 2004 Fair enough but i should warn you it is one of the worst alarm panels ever made 31851[/snapback] The key words are one of the worst - meaning there are plenty worst LOL
Guest Patmitch Posted November 18, 2004 Posted November 18, 2004 Fair enough but i should warn you it is one of the worst alarm panels ever made 31851[/snapback] I don't need advice on it functionality I need the codes
Guest Patmitch Posted November 18, 2004 Posted November 18, 2004 I don't need advice on it functionality I need the codes 31855[/snapback] Thanks for the help
breff Posted November 18, 2004 Posted November 18, 2004 If the codes aren't the defaults you've had it, that panel cant be factory defaulted. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Patmitch Posted November 19, 2004 Posted November 19, 2004 Not according to the user guide see below this has been cut and pasted direct from the user guide. Lost Codes The Installation Engineer has no way of finding out what your 4-Digit Access Codes are. If you lose the Master Code he will need to clear out the Code Table and re-instate the Factory Default codes. It will then be necessary to set up a new set of Codes for the Master and General Users. Note that the Regent Codelock system incorporates special features to frustrate attempts to find out the code by a trial and error method.
breff Posted November 19, 2004 Posted November 19, 2004 And to do that you need the ENGINEER CODE!!! The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest IM_Alarms Posted November 19, 2004 Posted November 19, 2004 I love it when a plan comes together ...... Doh!
Guest Posted November 19, 2004 Posted November 19, 2004 You spoil the fun, I was going to keep that bit quiet and wait till he tries getting into engineer mode!
Mister_Dave Posted November 20, 2004 Posted November 20, 2004 Is that the one where you have to take the lid off and enter the code to get in eng mode. Dave Oxendale York based security systems engineer.
