Hello,
Had an alarm system fitted in my home around 8 years ago. The original installer came last year and serviced it & fitted a new battery in the control box etc. Everything works great. He has since retired and moved away.
I’m just about to get an electrician to re-position one of the PIR sensors and I’m wondering how I tell the alarm not to go off when he’s doing the work!
I’ve got a Eurosec CP8L keypad and I know the engineers code but could someone tell me the process for putting the system into a sort of ‘maintenance mode’?
And then how to get it back to normal service afterwards?
Ive read the manuals but I haven’t a clue!
13 minutes ago, scuttle101 said:
Hello,
You paying electrician to be a labourer ?
He has to know how to do it himself as jw said
In a stern voice, depending on firmware
1.)rochdale accent
2.)yiddish ?
Posted (edited)
Enough already!*
In any case, won't any installer that isn't the original one probably have to crash the system? I can't remember now if it's full factory reset or codes only on this one...
Of course, it might be user tamper reset, even on case tamper, which IIRC is the default.
*that's what you can shout, covers both bases
Edited by datadiffusion
1 hour ago, aissecur said:
on this one its 4 buttons to default on power up unless the NVM is locked  (wont post for obvious reasons)
No one locks anything except me
