Posted (edited)
Hai
I have scantronic (cooper)85EN alarm every thing is clear .i connect    my sd1 + device .when the alarm is on .I receive a call from Sd1+ device .one s I receive call when I press number 8 this call is not going acknowledgement ,
Problem 2
this key 8 was working before that Time I receive call from sd1+ .when I press key 8 the alarm not going to off
please any one know the issue just help me out of this I am stuck in my project
(EDITED - PLEASE DONT BUMP ANCIENT TOPICS)
Edited by datadiffusion
Have you checked the programming to see if it has lost it's settings?
Is it brand new or 2nd hand?
1 hour ago, Ans said:
Hai
Problem 2
In acknowledge settings is it set to acknowledge once ?
using testbutt on line,  press 8
if works, its neither the line or dialler
if doen'st wotk remove every item inc adsl router & try again
Posted (edited)
In my sd1+ there is tirig input mention
A B C D/abort
in this slot which letter I want connect in my alarm panel .i want use resister or not
I give connection from my alarm panel ( bell out put ) to SD1+ letter C asper manual C is using for alarm
but I not respond in this device
Edited by Ans
