Guest Posted November 28, 2004 Posted November 28, 2004 Im referring to internal fixed IP on your network. 33030[/snapback] That's where we're all going wrong then, everyone else is on about the WAN IP address, which by default is usually dynamic unless you specify a fixed IP when ordering.
secure4 Posted December 3, 2004 Posted December 3, 2004 If you need any help setting up any of the above, ordering parts, routers, modems, switches, leads then PM me. Also, if you want me to make up a cat5e to spec for you then let me know. 25 metres is not a problem. Regards. Mark secure4.me.uk digital cctv
