It doesnt quite work that way, there is an app for galaxy its called GX I believe but it will only work with later panels. You can use an aftermarket app but you need the associated Coms Webway has an app that will work with most panels but you are limited to what you can do
If you have a Dimension or Flex panel with Ethernet module, you can use Honeywell GX app or SelfMon Virtualkeypad app to remote control your panel.
If you have a G3 or classic panel, only the Selfmon app will work.
If you have a G2 panel, then only the Selfmon app will work, but it needs an LCE-01 Ethernet module fitted.
The Selfmon app also works with webway module and any other module that has passthrough, giving full remote keypad control too.
Monitoring via push notifications is free. Selfmon has a minimal account charge and multiple options for path checking and message notification types.
  • Like 1
  • 4 weeks later...
Hi galaxy guy,
ive recently purchased galaxy 48 panel and it came with webway ethernet board with sim slot.
how do I set this up on the panel menu and which is the best app to self monitor this with.
Will appreciate very much for your help.
To use a webway, you'll need an installer. For diy, you're probably better getting an e080-8 Ethernet module.
Thanks galaxy guy.
Its all installed, but can the ethernet part be used for self monitoring with a GX app?
Am not concerned about using the gsm facility on it at the.moment.
1 hour ago, jitesh said:
Thanks galaxy guy.
No you can't use the webway module
Buy the ethernet card e080 and then use gx app (Honeywell app is rubbish by the way
Selfmon tho and virtual keypad works well
On 21/10/2019 at 16:51, Nova-Security said:
As said here
  • 2 months later...
Can the Flex V3 with the ethernet module be setup for self mon or gx app without needing the RSS software?
I read somewhere the RSS is need to set the UMS password etc?
Thanks
Ian
Thanks
Ian
You can everything without rss
