Hi can anyone help me I need so replace my internal sounder I think I have bought the correct replacement. the old one looks like a CQR soint2 with blue plastic insert for the cover screw inside just a simple connector bloc as the pictures show
the new one I have bought is a CQR soint2 hi-lo and has circuit board and unfamiliar connections on it
Am I right my green and white is my tamper and red = 12v and black negative hi or low
or
have I bought the wrong thing, if not how do I wire it in correctly
thanks
or
thanks
Please dont post multiple topics for the same question its irritating
15 minutes ago, sixwheeledbeast said:
You have a Soint loudspeaker and have purchased a Soint sounder.
It there a reason for replacing it?
Yes the original had a broken casing
If you want you can reuse the old electronics in the new casing, it's likely not worth the cost to send back and replace for the right model.
Just be careful you don't break anything when swapping the insides over.
  • Like 1
I’m upgrading the pir detectors and putting in a new keypad at the same time and looking at the two sounders it’s not just a simple case swap I think the new one will work fine just want to know what terminals to wire in to on the new one
Sorry new to site and didn’t really know where to go
But how do I stop the case all the tamper switch is fitted to the circuit boar and in to the case don’t think I can get the tamper switch out without damage
