20 hours ago, al-yeti said:
You can disconnect the tamper aswell and use that on a tamper circuit
Either way you can't use that circuit board on the speaker output simple
Ok I think I need to return it am I right I’m needing to CQR soint1 I posted about earlier
Al-yeti I know what others have said about simply swapping case and cut this and cut that but when you’ve just spent best part of £30 getting what you had been told before was the right part to get then your forgive me for being a bit reluctant to start cutting wires and swapping this for that
also new to this site and this topic should have been posted in the diy installer forum not in here
but thanks all for advice and assistance
Posted (edited)
So sounder was £30? Didn't realise you paid so much thinking it was speaker
Apologies , yes hope you kept packaging return won't cost you more than a fiver and probably cost you £17 .50 in end for speak not to bad in the end
Edited by al-yeti
