norman Posted January 7, 2005 Posted January 7, 2005 It's not to reg's as the cable is technically unmonitored. Nothing is foolproof to a sufficiently talented fool.
C.S TEK. Posted January 7, 2005 Posted January 7, 2005 exactly but it keeps both the customer and company happy. I have seen access control done this way and cctv. But it seems very unsecure for intruder. erhaps it belongs in the DIY Section chris Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
Guest Mickie D Posted January 8, 2005 Posted January 8, 2005 I could wire my kettle with cat 5 and it would work 36375[/snapback] you think you could pull 1850W-2200W / 2-10amps though a strand less than 1mm and it would work ? but i am learning about alarms and the best way is the right way use the correct cable for the job and however i might not agree with peters way of putting it but what he is saying is spot on !!!
C.S TEK. Posted January 8, 2005 Posted January 8, 2005 bet u could. 4 cores for pos 4 cores for neg most kettle arnt more than a metre away from the socket. u could probably run a 7kw shower of it if it was next to mains board. Chris Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
Guest Mickie D Posted January 8, 2005 Posted January 8, 2005 bet u could.4 cores for pos 4 cores for neg most kettle arnt more than a metre away from the socket. u could probably run a 7kw shower of it if it was next to mains board. Chris 36445[/snapback] maybe the kettle with 4 cores used but i was under the impression he was using 6 for the PIR and 2 for the kettle ? i still think the properties of the wires would burn out very quickly
Guest Posted January 8, 2005 Posted January 8, 2005 wire the pir E.O.L. and you have an extra 2 cores for the kettle
Guest Posted January 8, 2005 Posted January 8, 2005 not long peter the cable would proberbly melt within seconds of curren being applied . as for the megga problem we have 2 engineers me being one of them 1 manager and 1 trainee, 3 meggas but only 1 of them is calibrated so the other 2 just stay in the cupboard in the corner
