Andy cb Posted November 12, 2019 Author Posted November 12, 2019 1 minute ago, PeterJames said: They must be busy round your way So you can see why I’d like to diy it myself am i right in thinking That if I default reset with the old pad I place still then replace keypad with new one I shouldn’t run into any problems swapping the pir’s after system is all set just with new keypad Quote
PeterJames Posted November 12, 2019 Posted November 12, 2019 2 minutes ago, Andy cb said: Cheers I was planning on doing it when the system was completely powered down anyway The external sounder should start sounding on its own battery if you fully down power the panel. I say should that is what it is supposed to do. So You really need to start at the external sounder, go outside and disconnect that first, otherwise you will upset your neighbors Quote
Andy cb Posted November 12, 2019 Author Posted November 12, 2019 1 minute ago, PeterJames said: The external sounder should start sounding on its own battery if you fully down power the panel. I say should that is what it is supposed to do. So You really need to start at the external sounder, go outside and disconnect that first, otherwise you will upset your neighbors Ok can I disconnect that before I power down or after Quote
Andy cb Posted November 12, 2019 Author Posted November 12, 2019 1 minute ago, Logan said: Newer scantronic keypads wont work. You can only 9651 keypads on a 9651 I have a 9930 pad on there now from what I understand the 9943 works well and comes highly recommended for the 9651 panel Quote
PeterJames Posted November 12, 2019 Posted November 12, 2019 1 minute ago, Andy cb said: Ok can I disconnect that before I power down or after Before otherwise it will sound as soon as you power down. It will sound when you try to disconnect it but not for so long Quote
Andy cb Posted November 12, 2019 Author Posted November 12, 2019 1 minute ago, PeterJames said: Before otherwise it will sound as soon as you power down. It will sound when you try to disconnect it but not for so long Ok great Quote
sixwheeledbeast Posted November 12, 2019 Posted November 12, 2019 Considering the mix up just with just your speaker, I would think twice about DIY. Unless your willing to take the risk of many hours/weeks learning on the job and no guarantee of a working alarm at the end of it. Words of caution if you do DIY:- External bell strobe unit has very high voltage, this and having to disconnect a sounding box on the wall up a ladder is not the most pleasant experience when you have no idea what you are doing. Be careful. Obviously the control box has mains voltage in best to isolate if your not good with electrics. Quote
PeterJames Posted November 12, 2019 Posted November 12, 2019 1 minute ago, Andy cb said: I have a 9930 pad on there now from what I understand the 9943 works well and comes highly recommended for the 9651 panel II believe you are correct, I am not that familiar with Scanny anymore but I am sure someone posted here that the newer rkp's are compatible Quote
Andy cb Posted November 12, 2019 Author Posted November 12, 2019 So just to get this right 1 disconnect external sounder battery backup 2 default reset panel to reset engineer code 3 wire in new keypad 4 check system all working normal having reconnected external sounder 5 power back down and external sounder and swap pir’s 2 minutes ago, PeterJames said: II believe you are correct, I am not that familiar with Scanny anymore but I am sure someone posted here that the newer rkp's are compatible From what I’ve read on security warehouse it should work fine and I’ve read it on other forum’s Quote
PeterJames Posted November 12, 2019 Posted November 12, 2019 1 minute ago, Logan said: When you open the the panel disconnect what i put a red arrow pointing at NO!!!! diss the mains at the spur before opening the panel 1 Quote
