Gareth_B Posted November 13, 2019 Posted November 13, 2019 I have an existing (old school) Optima alarm panel with 2 zones (wired PIR's + contact points). I am looking to replace the panel with a simple alarm panel (no smart/wireless PIR inputs needed). I am looking for it to have the ability to arm/disarm using a remote control or a key fob. (The alarm will be used by elderly people, so the key fob/remote should be much easier than entering the code each time). Any thoughts on a suitable simple systems are welcome. Quote
aissecur Posted November 13, 2019 Posted November 13, 2019 You could use a Pyronix enforcer, it has two wired zone inputs (if you don't need to wire the external bell box) - note if you use the two wired inputs and want an external bell this would have to be wireless It has wireless fobs / and or prox tokens & is fairly simple to use Or another suggestion would be a texecom 12W (or similar) , fairly similar to the enforcer (probably better IMHO) it has at least 4 wired zones, it is wireless capable for expansion, has wireless fobs / prox tokens Hope the above helps Quote
sixwheeledbeast Posted November 13, 2019 Posted November 13, 2019 I'd use an Elite 64-W LIVE with either prox tags or smartkeys myself but I imagine everyone has there own preferred equipment. Quote
MrHappy Posted November 14, 2019 Posted November 14, 2019 10 hours ago, Logan said: Can i have the old panel i have been looking for a old optima for ages I think you need to explain your circumstances when asking randoms for their old junk 1 2 Quote Mr Veritas God
al-yeti Posted November 14, 2019 Posted November 14, 2019 14 hours ago, MrHappy said: I think you need to explain your circumstances when asking randoms for their old junk So what junk you got mr H? Quote
