EDinMK Posted November 18, 2019 Author Posted November 18, 2019 hmmm Perhaps i am being a bit dumb I drew a little drawing Basically even if i put a spacer under the mag contact on the window, and get it to the same "height" as the wireless sender ...the sender is too far away (if you get me) i mean it is a upvc window but it has fancy plastic 18mm bead around everywhere, and so there is no SQUARE finish between the fram and window anywhere I hope u get what i mean Quote
james.wilson Posted November 18, 2019 Posted November 18, 2019 alternatively fit an external wired contact to the frame/window and wire that into your transmitter Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted November 18, 2019 Posted November 18, 2019 49 minutes ago, EDinMK said: hmmm Perhaps i am being a bit dumb I drew a little drawing Basically even if i put a spacer under the mag contact on the window, and get it to the same "height" as the wireless sender ...the sender is too far away (if you get me) i mean it is a upvc window but it has fancy plastic 18mm bead around everywhere, and so there is no SQUARE finish between the fram and window anywhere I hope u get what i mean Screwagnet to curve if your not fussed realistically you won't ever remove the magnet or contact , but may replace it and if you move who cares Quote
EDinMK Posted November 19, 2019 Author Posted November 19, 2019 what a a testicle ache i just looked at my windows and these are almost identical i dont know what they cant make some form of "wedge" to fix them to ..i really dont something like this could work,as long as the tape was strong enough ...no reason it wouldnt work ? screwing is an option too Quote
james.wilson Posted November 19, 2019 Posted November 19, 2019 You want to screw them not stick. Alse re wedge etc there are thousands of window profile so it's either additional rf sensors or wired. As above I'd use a flush contact(s) but ob my own windows I only use the shock element Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted November 19, 2019 Posted November 19, 2019 1 minute ago, james.wilson said: You want to screw them not stick. Alse re wedge etc there are thousands of window profile so it's either additional rf sensors or wired. As above I'd use a flush contact(s) but ob my own windows I only use the shock element You don't use magnets ??? or no lunatic kids like mine who leave windows open day and night Quote
james.wilson Posted November 19, 2019 Posted November 19, 2019 I don't, but I will put them on when I upgrade the heating to room thermostats. I'm currently only using trv and the alarm to set the heating mode, ie comfort(disarmed) , night (part set) or economy (armed) I will shut off rads based on window and door contacts Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted November 19, 2019 Posted November 19, 2019 22 minutes ago, james.wilson said: I don't, but I will put them on when I upgrade the heating to room thermostats. I'm currently only using trv and the alarm to set the heating mode, ie comfort(disarmed) , night (part set) or economy (armed) I will shut off rads based on window and door contacts I got mags/shocks on all windows now , althought front is contact only would have been nice if mini contacts were being distributed now Hope it doesn't have some lunatic battery Quote
james.wilson Posted November 19, 2019 Posted November 19, 2019 36 minutes ago, al-yeti said: I got mags/shocks on all windows now , althought front is contact only would have been nice if mini contacts were being distributed now Hope it doesn't have some lunatic battery Its not using a cr123 but then it is little new keypad is priority, but the contact will be close, in white brown and grey Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
EDinMK Posted December 2, 2019 Author Posted December 2, 2019 Well I have deceided to flog on this Yale Kit IA220, thanks to being misadvised several months ago I have ended up with a load of accessories that should work but dont they are for Easyfit system ...still 866 but not compatible ... anyway I am going to flog it all on ebay and get a decent one I initially looked at Pyronix and Texecom I am pretty sure the Texecom system would work out cheaper ...perhaps. what do you guys think I need a system that ** Comes with Wired Bellbox (the only wired kit i need) ** Comes Wireless Panic Button **Comes with a dialer or some way of notification then the standard kit i need is 5 x Wireless PIR 4 x Wireless Contacts Any Suggestions for me welcomed Quote
