Stellarat Posted July 2, 2020 Posted July 2, 2020 Hi, You might want to check out this solution: https://konnected.io/, sold https://smarthomealarms.uk/?v=79cba1185463 in the UK. I'm not affiliated with these companies and have not used this product and am sure that it is not compliant with any regs. I am not an installer and this is my first post - so go easy ;) Quote
MrHappy Posted July 2, 2020 Posted July 2, 2020 25 minutes ago, Stellarat said: Hi, You might want to check out this solution: https://konnected.io/, sold https://smarthomealarms.uk/?v=79cba1185463 in the UK. I'm not affiliated with these companies and have not used this product and am sure that it is not compliant with any regs. I am not an installer and this is my first post - so go easy being blunt 1st link is US diy tat 2nd link is the UK agent of the above Quote Mr Veritas God
jlo7 Posted August 5, 2024 Posted August 5, 2024 Hi all, fully realise that this is a very old thread, but I'm looking for guidance on exactly this topic! @DaveDave - what did you do with this in the end please? I also moved into a new build with a 9751 and all sorts of door and motion sensors, and I'd really like to somehow use them in a smarter system so that I can get alerts when I'm away, and integrate with my wider smart home system etc. Any guidance would be greatly appreciated! Thanks in advance, Jase Quote
PeterJames Posted August 5, 2024 Posted August 5, 2024 4 hours ago, jlo7 said: Hi all, fully realise that this is a very old thread, but I'm looking for guidance on exactly this topic! @DaveDave - what did you do with this in the end please? I also moved into a new build with a 9751 and all sorts of door and motion sensors, and I'd really like to somehow use them in a smarter system so that I can get alerts when I'm away, and integrate with my wider smart home system etc. Any guidance would be greatly appreciated! Thanks in advance, Jase You could just change the panel for a smarter panel, it depends on how clever you are really. If you are running home assistant or similar, then yes you can integrate some panels using I/O units, if you are just using phillips hue/ Alexa and crossing your fingers you will need to rethink Quote
