Hi guys,
so I just swapped my g2-12 for the flex 20, I have a Rio in the loft so had to upgrade. I’ve daisy chained  two keypads and the Rio but I can’t see the inputs or outputs on the Rio. It’s been a while since I touched galaxy but I have fitted hundreds, am I doing something silly or have things changed?
ive addressed it 2 then 3, tried 2 different rio’s and I’m getting the 0.9 second on and off green led on the Rio.
Panel, 2 keypads neither Max, one Rio, panel can see 5 system modules.
thanks in advance guys.
I just wired it directly to the data line at the panel and it’s found it, got to be a cabling issue. It’s strange because the keypads are either side of the Rio on the daisy chain.
So what option menu are you going to then?
How many outputs does the flex 20 support?
No option menu, it just wouldn’t configure when I exited eng mode. Luckily I have a couple of PSU’s in the loft so I could free up a pair for the data. All good now thanks.
Sorry I missed you saying inputs problem aswell lol
Good stuff
