GalaxyGuy Posted December 30, 2020 Posted December 30, 2020 Test the board is working by placing a wire link from 0v to T. If the tamper issue is then resolved, the issue is in your sounder tamper circuits. Quote
al-yeti Posted December 30, 2020 Posted December 30, 2020 On 30/12/2020 at 10:00, Galaxy Tim said: Hi All, I hope you can help me as I’ve tried all I can think of and not able to get rid of Aux Tamp error to exit engineering mode of Galaxy Flex 20. ~ I have two Deltabell external sounders and want to wire both into the Flex 20. I’ve an internal speaker too. ~ The Deltabells bells are wired into OP1 and strobes into OP2. OP3 has been used for internal speaker which I’ve not bothered wiring tamper circuit for. The +12v for deltabells is coming from the left side of the board. The 0v is wired into the 0v terminal to the right of the three OP terminals. The deltabells have two tamper terminals which I have wired and brought back to the board on yellow and green. Yellow is wired into the T beside the OP terminals. Other tamper terminal from deltabell is wired into 0v. What am I doing wrong? thanks Tim Expand Screw for tamper switch? Quote
al-yeti Posted December 30, 2020 Posted December 30, 2020 Also wire one bell at a time to see if each bell tamper clears If one doesn't then atleast you know the problem is there , if none do them maybe cable or panel problem or your wiring , But more likely your wiring stop breath start again and more likely the tamper screw you haven't put it in Quote
Tjeerd Posted February 22, 2021 Posted February 22, 2021 Putting a 1K resistor between 0V and T should solve it. Quote
james.wilson Posted February 22, 2021 Posted February 22, 2021 It's not a resistor it's a link. But that will bypass it if it's in use Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Tjeerd Posted February 22, 2021 Posted February 22, 2021 (edited) Many of the flex boards have a little deviation there, if a straight link doesn't solve the 0004 tamper, use a 1K resistor either in series with bell tamper or to link it out directly between T and 0V and it should work just fine. Edited February 22, 2021 by Tjeerd Quote
james.wilson Posted February 22, 2021 Posted February 22, 2021 Oh ok fair enough ive only ever used a link Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
al-yeti Posted February 22, 2021 Posted February 22, 2021 On 22/02/2021 at 15:02, Tjeerd said: Many of the flex boards have a little deviation there, if a straight link doesn't solve the 0004 tamper, use a 1K resistor either in series with bell tamper or to link it out directly between T and 0V and it should work just fine. Expand You mean they have poor manufacturing? Quote
Tjeerd Posted February 22, 2021 Posted February 22, 2021 On 22/02/2021 at 17:30, al-yeti said: You mean they have poor manufacturing? Expand Haha ... dunno if it was intentional, have seen it on the first few, none ever returned because of the "fix". Wouldn't classify it as poor manufacturing, maybe a glitch? My mind is still boggled over a panel without terminals ... Quote
GalaxyGuy Posted February 22, 2021 Posted February 22, 2021 This has nothing to do with manufacturing quality. It's a country specific setting and depends on the country code / settings selected. OP, if you have picked up a second user panel, set it to factory defaults using menu 51.17 - cold start. If the tamper still exist after that (with the link fitted), then the panel has a fault. Quote
