VCL Dome manual required
Guest stevejones
Guest stevejones
I need a manual for a VCL VC431 Dome.
Can any one help please?
Steve
No manual to offer, but if you got a problem then you can't do any worse than ask, I presume your not the same Steve Jones who was once (dunno if still are) the Southern Rep for VCL ?.
Guest stevejones
32018[/snapback]
Yeh your right I am not that Steve Jones!
Steve
Steve
32029[/snapback]
I know a tad about VCL domes and Maxcom stuff too Steve if you need any help.
PS:- If you're not that Steve Jones, could you be the one who hosted 'The Pyramid Game' back in the 80's?
Guest stevejones
32721[/snapback]
No that's not me either!
I have just purchased this used VCL Dome (model VC431) It's got a heater in it. I connected the heater to 24 volts DC and it got very hot and blown the end off. I assume the PSU should be 24 volts AC and that was why its blown but I am not sure.
Also I need to replace this power resistor (heater) but I am not sure what value it is. Its got these numbers on it C6S HSA25 1 0R J 9841. Can anyone help?
Last question do I connect the heater to run 24/7?
Steve
Steve this probably no help at all but i sould be pulling a one out of a job after crimbo, (at least i think thats what they are). Do they look like a biscuit tin with a dome on the bottom?
Guest cctvman
Hi,
Yep 24vac for the heater although i have seen a dc version & it normally has a thermo to kick it in when things get cold although i have seen them running in the summer :blink:
A kwick call to vcl tech support & they will happly give you the value of the component
Regards
Cctvman
Guest stevejones
Regards
Cctvman
33667[/snapback]
Thanks I called tech support they advised there are 12v AC and 24 Volt ones about. Apparently the new ones are both 12 volts and 24 volts. I managed to sort it by changing the power resistor to 50 ohms 25 watt it now runs off 24 volt AC.
Thanks for all your help
Steve
  • 3 years later...
I don't suppose you have any idea where i can get spare parts for a VCL dome do you? The red power cable has severed running from the rotary union in the neck of the unit!
Thanks
  • 2 weeks later...
