31 minutes ago, robbo173 said:
The language isn't the issue fortunately, anybody able to help set this touch centre up or reset it some how?
Do you have English version instructions?
Yes I have the full English instructions, the issue is that it doesn't seem to recognise the panel and won't go through the addressing or language options on power up even after pressing the reset button!
Can you upload some picture of the unit
OP, you will need to place the latest English touch center firmware on a FAT32 formatted SD card, then insert the card into the CP045 and power on. The touch enter will then re-flash its firmware and default. You should have received an SD card and firmware with the new touch center.
If you are a Selfmon customer, contact me via the Selfmon email for support. If not, then contact your installer.
All available online though
Yes, Honeywell now post some firmware releases to:
https://www.security.honeywell.com/uk/resources/technical-support/software-upgrades/galaxy-software-download-centre
No support if you brick your devices though.
12 minutes ago, sixwheeledbeast said:
Interesting that they have there firmware on a public FTP.
They don't care
And still no one has bought them .....
