Sirtoddius Posted December 21, 2019 Posted December 21, 2019 Hi has anyone had any experience adding Hik ip cameras to a hybrid Bosch divar 3000. They are both the same onvif profile, I’ve enabled onvif on the cameras but can’t get them to be seen on the Bosch Dvr. I’ve tried dhcp and I’ve tried assigning both ip addresses in the same range but I can’t get them on. Bosch have said they can’t help as they don’t offer support for adding non Bosch cameras. Quote
al-yeti Posted December 21, 2019 Posted December 21, 2019 1 hour ago, Sirtoddius said: Hi has anyone had any experience adding Hik ip cameras to a hybrid Bosch divar 3000. They are both the same onvif profile, I’ve enabled onvif on the cameras but can’t get them to be seen on the Bosch Dvr. I’ve tried dhcp and I’ve tried assigning both ip addresses in the same range but I can’t get them on. Bosch have said they can’t help as they don’t offer support for adding non Bosch cameras. Did you check the onvif port the cameras are using , the profile like s profile is a seperate issue You may need to manually enter the port 1 Quote
Sirtoddius Posted January 16, 2020 Author Posted January 16, 2020 Sorry for the extremely slow reply. I forgot I asked this question. I found out what what the problem was. The cameras Profile wasn’t set to administrator so it would not let the Bosch Dvr connect even though it could see it. 1 Quote
