Hi
I currently have a Texecom Premier 48 which I connected a Menvier SD-GSM to approx 12 months ago, I connected this to the outputs so that I could tell which zone had activated - took quite a bit of fiddling with but I got there in the end and all worked well.
I also set one of the outputs so that I received a text when the house was in "entry". I noticed that randomly (every couple of months) the texts stopped sending and would only work again after I powered the SD-GSM off and on again - not ideal!
This happened again recently and after I restarted the SD-GSM again it wouldn't work any more  the LCD display has bits of character missing and the mobile numbers have strange characters in them so I guess its for the bin.
My question is which GSM dialler would anyone recommend? I dont want to spend a fortune really. The ones I have in mind are the GJD710 and I have also seen at a local supplier a TELL Pager4 Pro 3G.IN6.R1
It needs to be GSM as I don't have a landline
Any advice would be appreciated
Many Thanks
It would be good to have 8 but it doesn't look like there is much out there except the Menvier ones so I suppose 3 would do. 1 for alarm, 1 entry and 1 exit!
Expand
Go to advent controls online they have one that will do for you
Forget the V2 Tel , it's far to complicated for what you want to do and will make your life difficult
