1 hour ago, veldy said:
tried this it didn't work keypad is still froze
A bit (a lot!) more information as to how you got to this situation would be useful
Panel model, new system - installed by you - has it ever worked, your experience with Texe etc...
Remove power and battery reapply it see if it un muddles it's firmware on restart
  • Upvote 1
I suspect another one-time-wonder poster who's already fixed it or moved on to DIYnot and won't be logging in again any time soon.
We don't know what the problem is so I don't see how cycling the power is useful at the moment.
System could be maintained or panel could be engineer reset on tamper for example.
Keypad locking is stored in the keypad so if it is this, removing the power would just put the system into alarm with a locked keypad you can't silence it with.
Pessimist
  • Like 1
5 minutes ago, Logan said:
Lets try to summon him.
I thought Beetlejuice, Beetlejuice, Beetlejuice was the way it where done ?
Going back to somewhere near topic, battery powered keypad...
