Its obsolete Im afraid you might get a used one on Ebay but they stopped making that panel around 20 years ago
3 hours ago, Logan said:
With respect Logan unless you are 100% sure that a product is compatible, you should not comment. If that guy had purchased the Honeywell keypad, and then tried to fit it, he would have at the very best scenario a waste of money, worst scenario buggered his panel.
Posted (edited)
41 minutes ago, Logan said:
Did concept 6 have a led display?
its a plastic panel from the 80's
gemini / concept had something like 12 or 20 cores between the controls,
it very unlikely anything but the correct product would work
I thought the optima 2+ was a 8 zone version of the concept 6
no, it was 4 & 8 zone product with either on board  or blank metal endstation
individual zone tamper IIRC
Edited by MrHappy
  • datadiffusion changed the title to Concept 6 - RKP replacement?
Hi Logan , here is a pic of the ADE Concept RKP , lots of connections , the Concept 6 RKP is connected by a 4 core to the cpu , but best bet is to replace with a ADE G4 or similar.
  • Upvote 2
1 hour ago, Logan said:
Looks like a cool panel for my collection
Good old days of dodgy ribbon cable
