aissecur Posted January 22, 2020 Posted January 22, 2020 Hi all, I need to quote replace an existing knackered flat intercom system, 6 flats & limited cores at the intercom so thought of using a 2 wire system. I've used Videx in the past and rated them but age old thing client doesn't always want to pay / wants options I would need vandal resistant intercom & its audio (no video requirement) Any one used any other good 2 wire gear? If so where is a good place to purchase / price up? Thanks In advance Quote
al-yeti Posted January 22, 2020 Posted January 22, 2020 8 hours ago, aissecur said: Hi all, I need to quote replace an existing knackered flat intercom system, 6 flats & limited cores at the intercom so thought of using a 2 wire system. I've used Videx in the past and rated them but age old thing client doesn't always want to pay / wants options I would need vandal resistant intercom & its audio (no video requirement) Any one used any other good 2 wire gear? If so where is a good place to purchase / price up? Thanks In advance Standard stuff ? https://www.tlc-direct.co.uk/Products/DE906.html Actually that is 4 core but there are others like it Quote
PeterJames Posted January 22, 2020 Posted January 22, 2020 1 hour ago, al-yeti said: Standard stuff ? https://www.tlc-direct.co.uk/Products/DE906.html Actually that is 4 core but there are others like it Not vandal resistant not 2 wire Imran,. I use door entry direct just call them tell them what you want and give them your email address, they will send you a quote 0208 621 6210 1 Quote
al-yeti Posted January 22, 2020 Posted January 22, 2020 42 minutes ago, PeterJames said: Not vandal resistant not 2 wire Imran,. I use door entry direct just call them tell them what you want and give them your email address, they will send you a quote 0208 621 6210 I said that lol about two wire Door entry direct are ok but make sure it's something available elsewhere aswell , some products they stop selling for no apparent reason, maybe because they the main SRS people? Quote
