15 minutes ago, al-yeti said:
Dude use Google man , probably best , your going in circles thinking perhaps DD or anyone else doesn't know the answer , but it doesn't work that way
I try and find a link for a tavcom course for you ;)
You don’t know do you
  • Downvote 1
On 01/02/2020 at 16:42, Nova-Security said:
Have you opened and forwarder ports 10001 / 10002
I think the push notifications use Port 10000. That wont open on my sky router and sky have no answers.
You wouldn't normally need to open anything for outbound traffic. Not on a home router anyway and not port forwarding, as that's for routing incoming traffic. Ie. For the app connecting back to your panel when you're not on your home network.
Ensure the panel gateway address (your router internal IP address) and the panel netmask in the panel menu 56.4 are correct.
Probably already reserved for something, you would have to look through the list of suggestions.
As above you would only need that for control when your not in, as most of the traffic should be going out
www.nova-security.co.uk
www.nsiapproved.co.uk
Thanks for your help
