SecureAlarms Posted February 3, 2020 Posted February 3, 2020 1 minute ago, Logan said: Yes I just couldn't get it from OP's diagram. Seems to be making things more confusing than need be. Quote
MrHappy Posted February 3, 2020 Posted February 3, 2020 4 hours ago, Steve23 said: resistors 1k & 3k ? tamper & alarm relay closed, circuit reads 4k alarm relay opens, circuit goes 100k> & alarm goes into tamper... Quote Mr Veritas God
Hillbilly Posted February 3, 2020 Posted February 3, 2020 26 minutes ago, SecureAlarms said: I just couldn't get it from OP's diagram. Seems to be making things more confusing than need be. But remember we are alarm engineers and that is basic diagrams to us. Quote
al-yeti Posted February 3, 2020 Posted February 3, 2020 24 minutes ago, Hillbilly said: But remember we are alarm engineers and that is basic diagrams to us. If you say so Quote
Steve23 Posted February 3, 2020 Author Posted February 3, 2020 1 hour ago, SecureAlarms said: 1k across the A + A. 1K across A + T. 1 Core in 1st A. Second Core in Unused T. Thanks I'm starting the understand things now. I like your explanation it's so simple even I understand it. Yeah that diagram was what I got sent by someone which confused me as it contradicted everything I'd been reading. Quote
al-yeti Posted February 4, 2020 Posted February 4, 2020 9 hours ago, Steve23 said: Thanks I'm starting the understand things now. I like your explanation it's so simple even I understand it. Yeah that diagram was what I got sent by someone which confused me as it contradicted everything I'd been reading. Don't worry I am still confused to this day , but hanging around here keeps my mind boggled proper and helps plenty 1 Quote
datadiffusion Posted February 4, 2020 Posted February 4, 2020 20 hours ago, Steve23 said: Although the manual does recommend Cat5 cable. Are you sure? I'd be amazed. It may mention screened cable for keypads and nodes, but this is still flexible type. Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Steve23 Posted February 4, 2020 Author Posted February 4, 2020 1 hour ago, datadiffusion said: Are you sure? I'd be amazed. It may mention screened cable for keypads and nodes, but this is still flexible type. Ah yeah I think I read it wrong its in the Peripheral devices section. Quote
datadiffusion Posted February 4, 2020 Posted February 4, 2020 (edited) Ah that's a new one, I'm not big on Galaxy/Honeywell, but IIRC they used to recommend screened Belden cable, again only for long-run peripherals. In fact, using any solid core wiring FOR ALARMS (OBVIOUSLY) is a really bad idea IMHO, from an installer 'boots on the ground' PoV. Edited February 4, 2020 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
sixwheeledbeast Posted February 4, 2020 Posted February 4, 2020 I agree with above all too easy for the stuff to snap and create faults especially if it's been in a while. Quote
