Timmymeads Posted February 9, 2020 Author Posted February 9, 2020 60295166198__516C6098-1914-44CC-B644-F28D22AAB618.MOV 60295171866__6A513E9D-1312-4C8E-99A0-754882D70C59.MOV Quote
Timmymeads Posted February 9, 2020 Author Posted February 9, 2020 Lol.. thanks mate I’ve got the manual also but doesn’t mention anything about that Quote
MrHappy Posted February 9, 2020 Posted February 9, 2020 1 hour ago, Logan said: Im trying to find your issue in the technical manual from 1995 Wrong book... Quote Mr Veritas God
datadiffusion Posted February 9, 2020 Posted February 9, 2020 #SadTimes Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
MrHappy Posted February 9, 2020 Posted February 9, 2020 35 minutes ago, Logan said: No it isn't. Its for vista, accord and galaxy 16 16+ and 90 err the book say 4140/ 4170 if you also have an accord book in the binder it might but prudent to post a pic of that, I once had a 4140 on redcare.... not touched it 15yrs ? Drove by on tuesday, my sticker are still on the EWD's Quote Mr Veritas God
Timmymeads Posted February 9, 2020 Author Posted February 9, 2020 I know the engineer code now and master code - Do I have to program my zones? How do I enter programming mode Quote
datadiffusion Posted February 9, 2020 Posted February 9, 2020 2 hours ago, MrHappy said: Drove by on tuesday, my sticker are still on the EWD's Customer is well happy - he can show the world he is protected by a trading alarm company Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
al-yeti Posted February 9, 2020 Posted February 9, 2020 53 minutes ago, Timmymeads said: I know the engineer code now and master code - Do I have to program my zones? How do I enter programming mode When you defaulted you reset everything and will be time consuming to sort out I assume before you did the default you made sure programming manual was available etc? Quote
Timmymeads Posted February 9, 2020 Author Posted February 9, 2020 Not sure... what u mean - I just wanted it to work Quote
al-yeti Posted February 9, 2020 Posted February 9, 2020 1 hour ago, Timmymeads said: Not sure... what u mean - I just wanted it to work Well you need the manual , and you need to understand what defaulting does and what the alarm does It's better to scrap it tho and if you intend to try and make "something work" get a scantronic 9651 and it will be easier to setup and you can work your way through the faults over the 6minths to few years if that's what it takes Sometimes it may work to an extent but you can never realised the problems , you will have to get or ask for help on each problem that occurs Quote
