Steve23 Posted February 8, 2020 Posted February 8, 2020 Hi. I've been testing my Galaxy flex 20 still and everything seem to be working fine now and arms/disarms fine etc. Can I edit what is displayed on the keypad banner at the moment it's just showing the model name and number. And also when the alarm is armed is there a way of having it display on the keypad that it's armed ? I've looked through the manual but can't see any mention. Cheers Quote
al-yeti Posted February 8, 2020 Posted February 8, 2020 15 minutes ago, Steve23 said: Hi. I've been testing my Galaxy flex 20 still and everything seem to be working fine now and arms/disarms fine etc. Can I edit what is displayed on the keypad banner at the moment it's just showing the model name and number. And also when the alarm is armed is there a way of having it display on the keypad that it's armed ? I've looked through the manual but can't see any mention. Cheers Does flex have anything in menu to say banner? That's what was on older versions Set display , probably not unless switching off the en thing and it allows it , I am guessing Is keypad visible from outside to know it's set or not? As that would be disadvantage if you get me Quote
Steve23 Posted February 8, 2020 Author Posted February 8, 2020 1 hour ago, al-yeti said: Does flex have anything in menu to say banner? That's what was on older versions Set display , probably not unless switching off the en thing and it allows it , I am guessing Is keypad visible from outside to know it's set or not? As that would be disadvantage if you get me Ah yeah you've got a point there about the keypad being visible didn't think about that. I'll have another look in the display settings see if I've missed it. Thanks Quote
