John Mc Posted February 11, 2020 Posted February 11, 2020 Hello, I am looking for advice on a Karizma iD system installed in a house i have bought. I am in the process of installing down lights and needed to isolate the lighting system but unfortunately the alarm system is also connected to this supply. The issue is that when i cut off the supply, the alarm starts to instantly sound and there is no power to the keypad to enter my code. Does this mean the main back up battery is dead? Any help would be great. Thanks John Quote
norman Posted February 11, 2020 Posted February 11, 2020 Hi, Yes it is most likely the back up battery, relatively cheap to have it replaced and would also negate the risk of damage to the main panel through trying to charge a defective battery. Quote Nothing is foolproof to a sufficiently talented fool.
sixwheeledbeast Posted February 11, 2020 Posted February 11, 2020 Yes it's likely the system hasn't been serviced in a while and the standby battery is shot. Karizma is pretty old and obsolete they are also known to have issues with the NVM over time especially when they haven't been serviced. Also the detection is on a BUS (iD) wire configuration which is pretty uncommon. If you are doing a bit of work in the house and plan to use the alarm, it's worth considering the upgrade options. Quote
John Mc Posted February 11, 2020 Author Posted February 11, 2020 Thank you very much for the speedy responses. It is very much appreciated. I have only been given one code for the alarm by the previous owner, how do I know if this is a manager's code or a user code? I would obviously like to change the main code for my use. Quote
sixwheeledbeast Posted February 11, 2020 Posted February 11, 2020 Manager code should have an option to edit all codes. User code would only be able to edit there own. Quote
MrHappy Posted February 11, 2020 Posted February 11, 2020 8 hours ago, John Mc said: I would obviously like to change the main code for my use. I've just looked at our database, we was fitting this sort of tat in 1997, which is 23 years ago.... Do you like dogs ? 1 Quote Mr Veritas God
